1998 Honda Transalp, 28,000 miles MOT until July 2021. Reg number ending in XRV. Frame and swinging arm powder coated, Front and rear wheel off a 650, rim and hub powder coated, spokes heavy duty stainless, New Front disc, all seals bearings bushes on wheels, speedo gear , front brakes off 650; seals and dust seals, Master cylinder seals, hel brake lines, Rear wheel Including sprocket carrier, seals dust seals, OE front sprocket and rear sprocket and chain. New exhaust seals , and clamp. Taper head bearings top and bottom, New fork seals bushes and dust seals, New suspension bushes seals collars dust seals, and bolts swinging arm seals bushes dust seals, All filters and oils, Clutch , speedo, throttle cables, Seat recovered, there will be lots more but can’t remember, anything needed has been done. I’ve rattled can bodywork 1991 purple and silver, same as my first one stolen in 1992, it was only to use for a bit as I had sorted to wrap in Africa Twin colours, but not doing now, Engine runs well, everything works as it should, New continental attack tyres, everything has only done 11 miles, not engine, any questions just ask. Located in Goole.
165550
165552
165553
165554
165555
165556
165557
165558
