Hello
May I ask for your patience before I begin !
I to own a Honda motorcycle - all be it it is a VFR 800 1998.
I was carrying out a web search for 'copper grease' and low and behold I picked up on a link in this forum (Transalp) about using copper grease on the front drive shaft splines to prevent the 'fretting' of the front sprocket teeth against the spline. A quick search showed that the damaging and in some cases the total distruction of these splines is not uncommon amonst you chaps. Well guess what, its not unheard of on the VFRs !!!
The splines on my bike have started to wear and at least one other owner of a VFR has reported in as having the same problem. His soloution was to use some locktite bearing fit to 'glue' the sprocket in place. My solution was to use a propritery 'liquid metal' in place of the locktite as I found the locktite did not last very long.
Well to cut a long story short - all was well for a few thousand miles but my sprocket came lose once agian, at least I could hear that it had come lose as the sproket jumps slightly against the retaining washer and bolt, as it rotates. So I have just spent some time applying the liquid metal again. But of course on seeing thread
http://www.xrv.org.uk/forums/showthread.php?t=23284&highlight=copper+grease
and reading suggestion by the The Pheasant
that applying copper grease is a means of preventing further micro welding am am oviously interested in hearing if any of you good folks have used this method and found it to be a workable soloution to the problem. I am clearly wondering if what I have done was necessary and that a good coating would do the trick.
thanks
Jonathan
thanks
Jonathan
