Good day!
I'm from Russia. I have FMX650. This bike is rare in Russia.
I have a probleme.
My bike eats 500 ml oil for 50 km. The exhaust is good.
What is it?
Thank You
That much oil burning would produce much smoke at the exhaust. If you say that the exhaust is ok then it must be leaking somewhere. Take a better look. Don't know what you mean by frame.
Sent from my HT3 using Tapatalk
Typical oil problems in this engine is thr valve stem seals. Heavily worn engines will burn through piston rings. That much oil burning would give you white smoke in your exhaust when you rev hard.
How many times have you checked and re-filled ??
Sent from my G7-L01 using Tapatalk
I chek oil level each stop now. I started last week. I will write a result next week. The smoke is good.
May be i am blind:)
