Thought I would bore you with my tale of woe today.....
Got the plugs, got the filters, got the oil, got the time, all set for the sixteen thou' service today - a first working on the TA for me. But....
1. To do anything its fairing and tank off. About half an hour coz I've done it twice now.
2. Two of the plugs are a doddle. But the other two - I obvbiously haven't got the correct TA toolkit, coz I can't get 'em out [hex is too small for the plugs]. A tour round bike shops and car accessory dealers and no-one has a 12mm plug spanner. How the F**K are you supposed to remove the plugs then? And as for the front left plug - it looks like I have to take the radiator off as well. Does that mean I have to drain the coolant - I bloody hope not!!!
3. Right, on with the valves then. So that's the air box off as well - complete with 3 totally inacessible breathers and two equall inacessible carb top clamps. Remove one of the rocker covers, and then its down to the crankshaft end cover. IT WILL NOT BUDGE. 1 hour later with the corners of the cover about to round off, SOD it - the valves can wait til the start rattling. But looking at the other rocker covers it doesn't look like an easy job anyway.
Oil and filter will now wait for tomorrow when I have replaced that other plugs and can warm it up.
4. Stand up grabbing the throttle as I go and pull the heated grip straight off the throttle. Bugger, and start messing with the throttle and discover that it doesn't return - never noticed that before in use. Cable Oiler = another thing to buy Sunday.
five. Give up on service now and decide to fit Crash bars while the bike is in bits - following German instructions :? Eventually worked out had to remove two engine mounting bolts - the tightest things I have ever undone :x I actually lifted the front of the bike off the ground at one point. Anyway this was the onl success of the day.
6. While fitting crash bars notice regular drip from right hand radiator - nothing obvious but definitley coming from somewhere in the rad. SH*T!!
cry:
seven. Also discovered the Scotoiler isn't working {thougt it wasn't using much oil] - lost one of the injector pipes and the other is worn out.
: Dunno where the oil is going, but the chain is rusty now.
8. So tomorrow is trying to buy a plug spanner that'll fit a cable oiler and a filter wrench. Based on today I just know that filter WILL NOT COME OFF. :twisted:
So your wisdom sought: How the F**K do the plugs come out?; how long can I leave the valves?; should I just surrender and get it serviced at a bike shop?
Oh and I am pissed now - but have been very very careful typing this
