After an afternon spent fiddling with the bike and my Starcom and stuff, I decided to take the plunge and fit my Spotlights that have been gathering dust for 6 months or so!
I had a cunning plan the other day of using one of the existing fairing mounting bolts and fixing the light brackets on there. I "offered them up" in a variety of places and indeed this seemed best.
So I set about the wiring, relay and all, and eventually arrived at the point of a test run. I've also bought an Autoswitch for them so I can fire the Spots up with a quick double tap of the Main beam flash button. Howevere I couldn't think where to find a feed that was purely "main beam".
I then figured I could take it off the back of the clocks, from the little and perhaps appropriately named main beam "idiot light".
I temporarily attached this wire (well, stuffed it against the + contact) and turned the key. Headlights were on, spots were not. Quick double tap of the pass/flash trigger and hey presto the spots fired up.
Marvellous I thought, and was just about to congratulate myself on being a genius when the new wiring I'd put in for the spots began smoking! SH!!!!!!!!!!!!!T!
I quickly turned everytihng off, and the wires kept smoking for a while and then settled down! Strangely it was only the one wire that connected the 2 lights together (presumed this would be ok as I used a "wiring kit"), the rest of the wires didnt seem to melt!
However, having fully crapped myself I whipped the fuse out from the relay connection, took off the melted wire and removed the lights! Ho-hum...what a waste of an afternoon!
