1 - 11 of 11 Posts
FYI to all AT owners, the biggest single improvement to performance i have done and i highly recommend you do,
is upgrade the Ignition map for decent UK and European fuel. The stock map is very retarded to run on crappy fuel found in the likes of Africa. My AT RD07A did not like to drop much below 3000 RPM ( or 2500 after exhaust mods) before the dreaded chain snatch set in, which i believe is responsible for the wear on the gearbox sprocket shaft.
After reprogramming the ignition map, the motor now will pull from 1500 RPM In top gear !
It is now so much nicer to ride and is now the bike it always should have been.
The only sensible way to do this (dont even think about moving the ign pick ups!) is to change the Ignition module to a modified pre programmed box, or a programmable box. But a slight hitch here, RD07 and RD07A boxes are different, the RD07 has twin pickups and the 7A only a single.
The map i used (brilliant!) came from this company who also supply pr-programmed or programmable boxes for a whole range of AT models etc.
Digital Double-CDI for Honda XRV750 Africa Twin (RD04/RD07)
They are a very helpful company and a contact name is Felix Möhrle <[email protected]>
However they dont do one for the RD07A !
There is another company called Carmo which does units, for the RD07 (not 7A) but they give very little information, which i was uneasy about.
The box i used for my 7A came from this company:
SPARKER HONDA TCI - IgniTech Přelouč
They produce all sorts of programmable ignition boxes for many motorcycles, race etc and from what i can see really know their stuff !!
You will need to program this with a laptop, but is not difficult and i just used the Ign map from the prev. CDI shop.
The supplied box just plugs in and looks identical to the original, very good quality.
If any one is interested, I have the ignition maps, std and uprated, along with wiring dias for the plugs, photos etc.
Do this and be amazed at the difference.!!
Interesting article
So which cdi version did you purchase from IgniTech
Also what is the difference between a standard and an uprated map ?
So it fixed your low down fueling maybe by advancing the ignition ? Any other benefits
If you click on the IgniTech link, it takes you to the model for the RD07A which i bought. Otherwise trying to find which box you will need from their range can be a bit tricky.
Trying to describe the difference between the maps would take ages, but basically the improved map gives more advance at idle and through the range. I have attached both maps so you can see. Ignore any of the blurb in the box underneath each map. I programmed the figures into the IgniTech unit (but graphed them out as a double check).
Your comment about fueling makes no sense as the XRV runs carbs not Fuel injection!! The fueling is a totally different chicken, this is just the ignition required to set off the combustion process to give maximum power at a given RPM, relative to the fuel Octane being used. If you used the improved map in Africa on some really low Octane crappy fuel, the engine combustion would detonate ( commonly referred to as Pinking) and could cause serious damage to the piston etc. If i did find myself in that situation, i would simply swap back to the original unit, in minutes.
You would not have to do that with the Digital Double unit as it has both maps in it, you just swap over a jumper connector.
Anyway, the upshot is that the improved ignition suits the 95 ron pump fuel and unleashes the extra torque and power from the engine. Haven't had a chance to check fuel consumption, but because you can ride in a higher gear at lower speeds, it must be improved.
Its your choice, but it is the single best modification (and i have many) that i have done to my AT.
Do it and you will not be disappointed!
FYI: I have been building race, rally and road engines for most of my life, Currently working at Mercedes F1,
so i think i know a little about this topic!!
Hi
I looked at their website and searched by products by motorcycle. The only AT listening is 1990-1995. I must be on the wrong page ?
Could you explain to me the two graphs you include in your post also it’s showing RD04 at the top but I assume we are discussing RD07a’s.
So you can upload two maps and switch between them ?
My bike is road use only with some motorways in between A roads.
Regards Dave
To recap: If you have an RD07 it is simpler to get the Digital double CDI unit because it has the correct updated map installed and the stock map.. If you are in Doubt, email Felix Mohrle there and he will sort you out. If you have an RD07A then the only option you have is use the Ignitech unit that i have put the link to. This comes with only a basic map, but you dont need to start the engine on it. You have to reprogram the map using the data from the Digital double site.
I only included the screenshots to show you the map differences. What you do if you want the map for any of the bikes listed RD04 etc is download their software (its all free) and maps and if you look at the screenshot where it lists the models there is a dropdown chevron, which will list the models. Select the one for RD07 and the map will be loaded into the software, ready for you to upload into the Programmable Version of their CDI unit. But of course, you are not using their unit, you are using the Ignitech box. You then just take a screenshot of the ignition map figures and program them into the Igni tech box. Fit box to bike and Et voila, job done.
As I have done all this, if you buy the Ignitech box, I can supply you just the advance figures to put in at set RPM points,
so you dont need to go through all the palava. If you really think you cant do that, You could either post me the box and i will program it for you, or take a trip to my house and i can do it there. I live in Brackley Northants.
FYI: It does not matter what sort of riding you use the bike for, the improved low down torque range will benefit everyone.
If you use the IgnTech box you will need the interface cable to connect the box to the laptop or pc. There is a small charge for this cable but it is advisable to get it to prevent any connection problems.
On the IgnTech software it has to search for a coms connection which by default is set to port 1 ( i think) Change this to all or any and it will set up ok and you can program the figures in.
This took me a while to figure out as i could not get the box connect to the laptop! The instructions from Ignitech did not mention this. All the other settings about crank sensors etc are all set up by default, so dont change them!
Digital double have an experimental updated map for 98 Ron fuel. I have not tried it and i think that the stock AT compression ratio does not warrant using 98 Ron fuel. If you raise the Compression Ratio to 10:1 or higher, using special pistons (i have considered this) then yes 98 Ron and ignition mods would be a good idea. I wont be doing it.
Fyi: If you download the Digital double software (free) from the CDI tuner screen, to see the various ignition profiles,
Click, Profile, then Create from Template. This will then load the various bike ignition maps, accessible from the drop
down arrow
under choose a template. You can then see the different maps to compare as required.
When I saw this thread I became very excited because this is an easy mod and it has a big gain. But being me I started to think how to complicate it :D
I noticed the guys at Igni Tech have this -> SPARKER DC-CDI-P2 - IgniTech Přelouč , which has a a TPS input and even has a second map so you can revert to the stock one if needed.
Personally I think that if you have an engine load sensor - better use it :) It's not like my XRV's CDI gives a damn if the sensor is plugged in or not, but maybe if you have a programmable CDI things could get better! Perhaps it's a good idea to tune this on a dyno...
Discussion Starter · #9 ·
Hi, this is exactly the unit i have used on my RD07A with tps etc. I'm not sure that you can have a second map, if you have it wired up exactly as the original Honda unit as i think the two input channels are already used. However, it is such a simple operation to just swap back to the original CDI for the std map hat this becomes a bit irrelevant.
As for a dyno test, again a bit pointless unless you have uprated cam profiles and / or compression ratio. True you may gain a little here and there, but the AT is not a race bike! I doubt you would feel the difference when riding.
The point is, the map that i have used is such a revelation to the std map, why bother.
I have done plenty of dyno test work in my time in motorsport that i can tell you that it is quite time consuming (expensive) and give you machine more hell and wear than you can ever give it on the road (rear tyre will be pretty mullered!). If you really want more more top end power, fit a straight through silencer (no 4 stroke LIKES back pressure), drill a couple of 25 mm-ish holes in the side of the airbox ( block off with tape in v cold weather). Fit a K&N air filter but machine off at least 25-30 mm of the top of the inlet snorkel that it fits over as it is too close to the filter for max air intake. This allows for filter area to be effectively used. Radius off the top of the snorkel edges. I used SUGRU (google it) to improve the radius for better air flow, but dont go mad and make sure the filter will fit over it.! See attachments, note the different colours of sugru are because i didnt have enough of one colour!! These mods do result in more induction noise (a roar!) but that does not bother me with (custom )earplugs (i wear all the time anyway).
These are the mods i have done and it improved it noticeably before the ign map mod. I did not have to adjust the carb fueling as mine always tended to run slightly rich, but always check the plug colour after de restricting the exhaust.
After the ign map change all the gains from these mods were enhanced. This is far more cost effective than a rolling road session, but if you fuelling is not correct, then yes a rolling road session is a must to prevent engine damage.
Do the airbox mods demand rejetting? I have also thought about the dynojet kits as it is again an easy mod which in combination with all the other mods you mentioned should have a big impact.
I have searched the web for photos or descriptions of XRV air box mods but until today I haven't seen any. Thank you for the detailed explanation! Just one question while we are on this topic - the holes should be blocked while riding in cold weather because of the air density? Or just to prevent water getting in?
The exhaust is already derestricted and fueling for now is OK but maybe if I do the airbox mods it will become lean.
Discussion Starter · #11 ·
I did address the carb re-jetting issue in the previous article, so rather than re do it again here, please re read the previous post. The dyno jet kit will not give extra power if the fueling is already within range except for track use possibly. You cant get more power by just dumping in extra fuel, just sooty plugs, bore wear and lighter pockets!!
Again i re-iterate, the Africa Twin is not a race bike. The airbox mods did not affect my carb jetting, the exhaust de restricting will have more effect on that, so if your plug colour is ok, stay away from Kits like Dyno Jet.
If the plugs show lean running, then perhaps a dyno jet kit would help, BUT always check your carbs are clean and free from jet blockages FIRST.
If you do go the Dyno Jet route, you really must have a rolling road session to set it and check it. I have seen too many Cylinder bores that have bad wear due to the oil being broken down by excess fuel (bore wash)
because the bright spark owner fitted larger Main Jets in the belief he would get more power, but did not get it dyno run checked!
Taping over the Airbox holes mods in cold weather will help prevent Carburettor Icing which can prevent the slide or butterfly from closing properly, which comes as a bit of a shock when you attempt to throttle back !!
This can happen particularly on long straight motorway type roads (even after a coupe of minutes) as the throttle is not being opened and closed as in normal more twisting roads. This is because of Bernoulli's principle : Where there is a drop in pressure (air flowing over the main jet in the slide or butterfly) there is also a drop in temperature, which can form ice if the ambient temperature is also quite low ( not necessarily freezing) and damp.
This has not happend to me on the AT as i ride generally in warmer weather, its just a precaution. It has happened to me several times in the past driving carburetted cars!
The normal air to the airbox is fed from between the V of the cylinders, so is warmer, but restrictive for top end power. The extra holes addresses the restriction and on hot days the air comes mainly from a cooler supply (fuel tank sides).
1 - 11 of 11 Posts
