XRV650 ignition switch XRV750
I am doing up my 1988 XRV 650 and the steering lock has been 'removed' out of the combined ignition switch/steering lock. The ignition switch still works. Is there a steering lock replacement 'barrel' or do I need a new switch. I have seen replica switches for the XRV 750, will they fit?
Any help or advice appreciated
James
Re: XRV650 ignition switch XRV750
Many companies make after market ignition switches. Have a look on ebay. See if the part numbers are the same.
Thanks for your reply
I have checked part numbers and they are different for each model. I have found from past experience that the part numbers may be different but the part can be the same/very similar. The XRV650 possibly shares its ignition switch with the XRV750 (or Transalp?) and I'm quite sure someone has tried this fit and has the information I am looking for re any mods required.
James
I have an aftermarket switch for a 750 you can try if you want.
It has a small crack in the plastic so I couldnt use it for a job.
