Rick, what sort of crimps do you use?
It's my understanding, correct me if I'm wrong, that a good crimp ensuring metal to metal contact (probably needing expensive tooling) is better than soldering; solder not being an especially good conductor??
Excuse me whilst I pick myself up off the floor where I've just been in fits of laughter for the last ten minutes!!!##
Fridge, ever wondered why all professional wiring looms, electrical equipment and everything else that connects two wires together that doesn't need seperating in the future use solder, if they do need to be seperated then they use a decent quality plug.
Think of it as cheese on your hamburger...put it on when the meat is cold it can be pulled straight off, heat it up a bit and there's no way of easily removing that cheese. The same with metal to metal contacts, a crimp will only contact less than 25% of the surface due to irregular surface area, where as Solder is 90%+
One thing that really should be pointed out is that soldering is a skill. Get it wrong and you might have well just twisted the two wires together. Get it right and that joint will be 200% better than any expensive connector.
Make sure that both sides to be joined are clean, if it's two wires then twist together. When applying solder firstly heat up the area to be soldered making sure that both sides are heated, then apply the solder (not too much) to the area and not to the soldering iron. You'll see the solder flow across the joint if everything is OK. Now the important final step which most people get wrong. When removing the soldering iron do NOT allow the soldered joint to move until it has solidified. If you do then it's a good possibility you'll create what people refer to as a dry joint (not electrically sound and prone to cracking.) The finished soldered area should have a bright shiny appearance and should not be dull in any way.
One other thing is flux, never use the flux that you get for plumbing, even if it does give you a fantasticly good joint. Plumbig flux is acid based (which is why it works so well) and once you put an electrical current through it the acid will react and slowly eat exposed metal.
Kymmy
PS..if anyone is wondering if I know what I'm talking about I spent 5 years out of my 15 in IT doing component level repairs on electrical equipment
