nowthen, i have a 2005 tranny, i want to get rid of the cat so i can use leaded peterol,so i was hoping to fit a end can off a 2004[ pre cat].does anyone see a problem, the end cans and fittings look the same
also does any one make a foam filter for a2005
cheers ben
cheers ben
Hi Ben and welcome to the forum :)
All the 650 Alps are essentially the same regarding emissions gubbins.
The cat/subchamber is part of the header pipe system, not in the endcan and lives under the front of the swingarm, a few of us have removed it and achieved better low-mid grunt and better fuel economy to boot.
This subject has been covered in great detail so do a search for more info or check out techtransalp.co.uk
What is described as a catylist is (i believe) not a true cat but a heat tube to super heat the spent exhaust gasses, so running with leaded fuel may be ok.
I believe that unifilter (Oz) do a foam element (modification) for the 650, but I don't think that anybody's had any joy purchasing one in the UK. I had a go at putting some car airfilter foam in place of the pleated paper, wasn't a real success but worth a go!
Phil
cats
hi phil thanks for that,so i dont need to change the end can ,but will it run on leaded fuel,do you know of anyone that has done this.
thanks ben
post
Leaded fuel is no longer made, do you mean super unleaded or Shell V-Power, or BP Ulitimate, i can think of no reason to use leaded fuel.
post
Hi Ben
Best of luck on your proposed trip, i think when you get to darkest Russia the octane rating of the fuel might cause the engine to pink a bit (a tinkling noise on acceleration) but maybe Russian petrol is now the same octane as our own and the problem won't arise.
