1 - 18 of 18 Posts
Older, but no wiser!
I am starting to get the Project Kwacker towards an MOT and one of the issues that has arisen is a "sticky" front brake with the new pads remaining a mite too friendly with the disc.
I stripped the pads out and found the previous owner who has done most of the real work already :) had lubed the slide pins with bog standard grease and the whole thing was glooped up. I cleaned up the pins and the socket in the main assembly with brake cleaner but I was not able to get any pukka slider grease from the local auto supplies shop today. Years ago, when I last did this job on a bike, we used to use Copaslip, is it OK to use on more modern machines on the slick-coated slider pins?
G
Yep, though I tend to use silicone grease, it's just as heat resistant as copper grease but more slippy, a PTFE grease works great as well
Thanks Kymmy, I'll pop it together in the morning and see how it all feels, it cannot be worse than it was!! :)
Just the oil feed to sort out after a proper run and then MOT time and then Wales....
If you've got a decent motor factors locally, they sell RED GREASE which is used for the slider pins and is compatible with the rubber boots.
The red grease I've bought recently came in small "ketchup style" sachets rather than a tube or tub they used to sell it in.
Bob :thumbup:
Bob :thumbup:
That was what I was trying to get from the factors, but they said they sold so little in the tubs, they didn't stock it!
Nexus 6
Mmmm, not a big fan of coppa-slip in this application - it tends to dry out a bit and 'ball' up leaving dry areas and thus wear/corrosion sets in. I much prefer normal LM type grease changed pretty regularly but No1 choice is the red stuff if you can get it.
Would your choice be due to the fact that you have ample supplies of the stuff like me from our employers?
Hill Rider
Like Kymmy, I use silicone grease on any areas that come into contact with rubber seals.
The pins get copperslipped, as do the back of the pads, plus the pad tensioning spring thing that sits under / over the pads to help keep them from rattling.
Just my ramblings . . . . . shuffling off now :rolleyes:
Steve T
:cool:
Bling Tastic Transalp
Steve T
:cool:
I concur.. steve t
I did exactly what you describe when servicing my brakes last time, still working a treat.. thanks for the info last time...
I could not find silicon grease in the shop here, so bought from seller on fleabay
G
Steve T
:cool:
Errr, you havn't been borrowing it from the airframe techs have you?? Used to be my favorite place to get some :):):)
Talking though about copperslip use the spray and not the grease as it goes on thinner, is more slippy and less likely to go gloopy as it's the carrier for the copper that hardens
I just putted drive shaft (with molybden) grease in to mine.
Just happened to be near when needed :rolleyes:
i should have silicon based somewhere, I use it for caliber pistons.
Hill Rider
Might have . . . . . might just be a life ex pot that was being chucked out - maybe :rolleyes:
I thin copperslip down with some WD40 if I need a thinner coating (Kymmy - PX24 does the same job :rolleyes: :D)
Last of the Minoans
It's worth watching which you use, as GP/LM grease seems to make the rubber boots expand. Once that happens the boots won't fit the grooves, leading to dirt getting in and, eventually, corrosion and seizing. I just use red rubber grease now.
Discussion Starter · #14 ·
I'll try and get some red grease I reckon, as it looks as if I will have to strip the brakes on a regular basis according to a mate who used to off-road a KMX200. The 125 like I owned was a different setup, i gather.
Nexus 6
A'hem, errr, yes, but due to my recent 'retirement' my supply is running out so any donations are welcome. I've still got a natty Loctite deonstrator tube of copperslip in a pritt-stick type stick applicator - it really is just a copperslip pritt-stick - its so fantastic I haven't had the heart to use it yet! :p
Discussion Starter · #16 ·
Are you sure it doesn't say Avon on the outside, it sounds more like lip gloss to me! :)
Does the brand matter? For example, should I insist on Castrol, or will Heinz do just as well?
:joker:
Nexus 6
Nope, here it is below in all its un-used pritt-stick-like-copperslip glory......
How cool is that?!
1 - 18 of 18 Posts
