What do you do for long term winter storage really...I read many storage stories from the owners of other bikes, however it is AT...well in fact it is a high milage (72K)one.
I'm not sure if I should empty the tank and spray some W(onder)D-40 for rust of course also empty the carbs.What if I fill the tank full?. Also do you think it is necessary to do the same in inside of cylinder after taking off the plug...I'm planning a three month storage in a private garage.
Spraying WD-40 to the chasis where prone to rust and all over the engine is also okey but what about the rubber parts? do you have any idea about the long term effect of this product on rubber?
Changing the oil and filter but a cheaper oil just for the storage time and put a good one before starting the season seems logical.
I think I will not be able to find that apparatus to keep the wheels off the ground since I do not also have a center stand I'm planning to visit the bike often and change the point that wheel touches the ground. The cost of this two device is around 300E here in turkey and no used ones!!! (and a low salary
Any answers would greatly appreciated
