So, rode the TA to my first appointment this morning. Nice ride, nice exhaust note.
I have noticed that, when cold especially, below 3500rpm on the idle circuit, the back cyliner (seemingly just next to my left knee) makes a ffft, ffft sound on a constant throttle.
Do you get this?
I'm thinking that the bike may be a bit lean on the idle circuit after the Arrow restrictor came out.
Whaddya think?
Best way to tell is to remove the spark plugs and check their colour.
Well, I think I may have found a more likely culprit than the Arrow:
There was a 2mm hole on the under side of the fuel tap vacuum pipe which explains the sucking noise I kept hearing and it explains the lean running. I've cut the pip up to the hole a reconnected it: any more and I'd have a kink in the pipe, but so far the bike is running much better...
heck, the clutch was not even slipping :rolleyes:
