It cost about £30. However, it wasn't branded as a copy. But yeah, too cheap. However it was a generic model. Without the connectors for the AT (which I knew I wasn't going to use).
I've replaced the cheap fuse holder with a MIDI fuse holder and fuse. These are more robust than a MAXI.
The Reg/Rect does get hot too. After five mins on idle it's too hot to hold comfortably. I thought these should run much cooler.
I get 15-15.3v on idle. Headlights drop it to 14.5 and adding heated grips drops it to 14.3. (On idle)
I've added a voltage gauge to the bike so I can monitor it and see what voltages I get on a run.
14.8v is max voltage you really want to be putting into a 12v lead acid battery.
I may be swapping it out for a genuine.
I've run both my outputs DIRECT to the battery. (with the fuse on the Pos. obviously).
I've read people earthing directly to the frame. However, the earth strap for the motor/starter is on the same terminal so I really doubt that makes any difference.
I just need to find the same to go for a run. And have the wife ready with a spare battery in the car incase it fails me.
