1 - 2 of 2 Posts
Looking to replace all the fuel lines on my RD03 as a couple more leaking a bit nowadays. Rugged roads has 4or5 sizes. What is most common I would need? I plan on buying some bulk lengths. They have 4.5, 5.5, 7.3 and 8mm ID. Mine are so old going to be hard to determine sizes. I know I have used 5.5 a lot in the past on other bikes so planning on that. Thinking maybe 8mm should Cover the larger size. Any thoughts? Thanks
Measure the pipe stubs it goes onto. If you get 8mm, where you only need 6, it will be messy trying to squish it down to seal and you’ll need proper fuel pipe clamps, not the spring loaded Honda things.
1 - 2 of 2 Posts
