Hi! I was wondering if someone could give me a hint on this.
Last week I was driving home when suddenly the engine stopped ( like if I killed the ignition ).
I managed to pullover safely, and when attempted to restart the engine, nothing happened ( not even the relay click ).
Details:
- Ignition works ( lights in the dash, headlights, etc ).
- Neutral and sidestand switches work, on and off.
- engine did not overheat, oil and coolant levels are ok, and no signs of mixing. No signs of seizing either.
- Battery voltage is 12.9
- all fuses OK
- no power to the CDI and starter motor, it seems, and when I hit the start button the relay doesn't click either.
Before I start pulling everything apart, does anyone have a clue about what it could be?
Thanks!
Space Emperor
I had a problem like that a year or two ago ... it was a bad connection behind the speedo. Not the speedo itself, of course, but there's a hub, holding a bunch of connectors. Don't remember which one it was, sorry
Hey guys thanks for the input.
Well, I found the problem, have a laugh on me ( and here is my testimonial so that it doesn't happen to anyone else ).
I got the electrical diagram, took the tank out, and I started following the wires with the multimeter until I found a black and red wire that should have 12v and didn't.
That wire was coming from the ignition fuse. But I had checked the fuses! So I went and I inspected that fuse better... Holy ****ing shit! It was the fuse after all.
What happened was, when the fuse blew, it did not blew in the center, and when I checked them the first time, on the light of the end of the day, I just looked in the center. :tard: Lesson learned... always check the fuses thoroughly.
