Hi, I hope to rejoin the ranks of XL ownership having previously owned a 1982 XL 250s (have regretted selling it ever since).
I have been unable to find a decent 250s to invest in but have found a good looking 84 model with the RFVC engine and twin carb's. Now my predicament is that I have no experience with this motor and have it in my mind that these were prone to cracking heads? Are there any other concerns with this model that I should be aware of?
Thanks in advance for your replies, I have searched and read alot of threads but need to be convinced to buy it :sunny:.
Thanks Steve
They say I talk too much.
I don't think you need to worry.
The cracking heads are a problem of the 6oo series; in my opinion, that's only partially due to the fact that Honda used gingerbread instead of aluminium... for the other part it's caused by the valves being very large, so there is not much material around them.
On such a small bore bike, that ought to be better.
Thanks Krtek, I appreciate your advice. Good luck in the World cup by the way :thumbleft:
Wut? Oh... soccer. Yeah, thanks ;-)
TRF member
erm....i had a CB 250 RS that cracked the head,granted it was not RFVC,but 4 valve none the less...bloody good bike though:thumbup:
Oh, I'm sure it's possible for a small bore bike to crack the head... it's just not something you hear about all the time, as with the 600 cc RFVC engines.
Senior Member
Yes, it's fairly common for 250 heads to crack, . . . between valve seat and spark plug hole. . . . . just try to find a second hand head for a 250rfvc. . . . . but to be fair there are still loads about that are running ok.
if the bike is running sweetly its probably ok.
ps
there are a couple of good threads on here on 250 renovations.
Thanks for your help guys.
Is the head cracking avoidable or is it due to poor alloy or overheat probs.
I have an aversion to vehicles that die/fail due to poor design or materials.
I may have to wait for another XL to come along :(
I will read the threads on 250 engine upgrades however.
