1 - 10 of 10 Posts
I have bought some neoprene fourth gaiters and was wondering if anyone has navy experience of pouring then on?
Do you need to take the forks out of the steering head to get them on?
Or is there a simply slide in method from the bottom?
Cheers in advance
Older, but no wiser!
Fork legs out, can be easier to do one at a time and reposition the leg back into the correct position with the the wheel and spindle installed temporarily.
Simply you can call your seller sure they will help you to solve this issue.I hope you will get very quick solution Compare to another source.
And that was your first post?
BTW I am myself searching for a set of blue AT gaiters looking like the original, and hopefully of better quality. Any good source would be appreciated.
Lee
1 - 10 of 10 Posts
