Wing Commander
I suddenly realised I have been riding my recon RD04 for 12,000 miles. Effectively that is 12,000 miles from new (even though the engine had done 65,000 before the recon).
I have changed the oil and oil filter three times in that 12,000 miles but done nothing else - just abused it. I'm going to do oil again plus, fuel filter, air filter and plugs, and I'll adjust the clutch, but while I have the tank off what else should I be doing/checking/adjusting?
carb sync?
Wing Commander
Carb balance, valve clearances, lube choke cables if you still have them.
Do they have a gauze in the fuel tap?
3 filters in 12k sounds a lot.
I decided to change the oil every 3,000 miles. A new filter in what, £6?. It seemed when changing the oil I might as well change the filter.
I am not a tight-fisted northerner like you:blob7:
Check the gangle pin is torqued to 10Nm after you have balanced the carbs, as they do tend to undo themselves and get lost.
:thumbup:
Wing Commander
:thumbup:
Which gangle pin? The one just under the floojemeflip, near the ploonwrangle? or the one that connects the sprongawonga bracket to the flange?:lol:
  • Like
Reactions: Machiru
The WHAT pin??????
:thumbup:
