1 - 16 of 16 Posts
Bike came this am snd seems fine, brakes needed bleeding and a flat battery which is being charged.
First weirdism.
The cooling fans come on when I turn the ignitition on. Is this normal?
Beer monster.
Temperature sensor for the fan is in the right hand radiator. Unplug it first, see if the fan goes off.
Hmm
The kill switch seems to just control the cooling fans, but it starts and runs ok.
This looks to be a starting aid, taking the load of the fans off the battery, a bit odd.
What is the weird round thingy in the fuse box? I will post a photo later.
Off to sort out tax and take a test ride
Hmm
its a diode , think part of the side stand in gear kill I think...
  • Like
Reactions: chunkolini
Discussion Starter #10
Thanks for that, for a few seconds I figured some plonker had bodged a replacement fuse in but it looks like an official fitting.
Glad I did not yank it out.
I put about forty miles on it today, runs fine, no problems.
I even like the colours. I will post photos later.
Wing Commander
On both my RD04's the fan stopped working and replacing each individual part in the system failed to fix it so I wired it direct to a switch on the handlebar and turn it on manually in heavy traffic in the summer. Sometimes I then forget to turn it off so when I turn on the ignition the fan comes on. It might not be the kill switch, just one that looks very like it.
bit of a ###t to solder a new diode in, don't rag the old 'un out. carefully/craft knife etc, remove the back of the box before you do owt. last time, i just drew out the two wires, extended & added an in-line diode with adhesive heat shrink, tucked away for easy accsess if it needs replacing again . if
If this is the diode mate, according to the Honda workshop manual, it's the clutch one:
yup that's it the side stand one is in line under than tank on the left :thumbup:
Discussion Starter #15
Topbuzz99, that is the sucker. What the hell was going at Honda? that looks like incompetent home bodgery. I will leave it alone.
So far so good, bike seems to work fine, I will leave bizarre switchery alone for the time being.
There is a nasty wobble at about 85mph, I reckon the massive pile of wheel balancing weights might be a cause?
There is a threaded wotsit on on the opposite side of the rim, I reckon some kind of security bolt and flange to keep flat tyres on the rim.
my Tenere has these in Ghana years ago. Photos tomorrow.
The fan circuit is about as simple as you can get, the fan is powered from the ign switch vis a dedicated fuse - there is no relay. A thermo switch at the bottom of the rh rad allows the fan to earth.
99.99% of problems are either;
Corrosion at the thermo switch, or a bad earth from the rad, the earth is often accidentally left unconnected if a rad has been removed. Sometimes the fan 'sticks' blowing the fuse when the fan is required.
Phil
1 - 16 of 16 Posts
