Well, we had a long weekend in blighty, so I was hopeful to get a lot done...but while I did get a fair amount done, lack of rotor puller for the alternator stopped play. I have multiple pulley pullers, but all more car suited and just could not get a grip on this thing!
There were also some frustrations, so I'll pass these on as well. One thing I have established while not particularly difficult, this is very time consuming, especially when you are referring to te manual and deciding what comes off next and what needs to come off...pretty much everything is the conclusion!
So, first..and funnily enough, the biggest fristration, was takin the tension off the time chain tensioners. I move the crank to the right position and on compressions stroke..so all valves closed and measure as per the manual the maximum a metal wedge protruded. Above a certain amount, and your chain needs replacing on that side. Both mine were fine:
You are measuring this height here at a certain crank position.
So, all find and dandy. There is a wedge behind this..which slowly pops up and down as you change crank position..very slowly. You need to push the thick wedge down.grab this wedge, pull up and you'll see a hole...put a pin in it to hold it in this position. I used a split pin. But you think, 'ok, simple enough' oh no, grabbing this thing is a total PITA. There is a fair amount of tension and finding something that can grab onto it, pull up and then slide in a pin took me ages. I probably struggled for a good 30 mins...maybe more, to get this done! As the end was on a table, I ended up standing on a stool over this thing, pulling up and finally getting a pin in! One trick is, the manual says get the engine to TDC..check the wedge clearance, than grab the thin wedge....but at this point, the wedge is at the lowest. Turn the engine where this wedge is at it's highest and work from there..there is much more of the wedge to get hold of.
Finally done.
here the sprocket is loos and the cam shaft is out:
The rest of the strip down goes pretty smoothly. the parts will stay here until re assembly
Once the covers were off, undoing the nuts for the clutch and the alternator rotor were the toughest part/
I made the recommended locking tool as shown in the haynes manual!
Also useful in the zombie apocalypse!
Which worked well on the alternator bolt...but needed my longest breaker bar!
But even un staking the clutch center nut would not see it freeing off. Part of the issues that the engine is out, so starts moving, limiting the amount of leverage you can apply, so a tip might be loosen these off with the engine in the bike.
So I opeted for a Clark CEW1000 impact wrench...
