81 - 87 of 87 Posts
Discussion Starter · #82 ·
Another brilliant write up with good pictures thanks
Thanks! (y)I'm still blaming you for the splines comment that kicked all this off! :ROFLMAO: ..speaking of which, I still have to sort out the brake pedal splines. I may well go to the vapour blasters, where I will be starting off the conversation with 'now don't laugh' :rolleyes::D
Discussion Starter · #84 ·
Glad I could help lol after looking at the new one(output shaft) you did the right thing.
Yep, definitely the right thing. The whole process wasn't too bad and I'll be back on track in no time. I still think the paint work will be the main factor delaying getting the old girl back on the road, so I have time, and no real rush!
Discussion Starter · #85 ·
Discussion Starter · #86 ·
well, can't put it off, the engine has to go back.
Hood Motor vehicle Automotive tire Automotive exterior Bumper
Made some room and put the engine on vlocks, having tried without. the engine sat too low and I was not confident I could easily lift it up to sit properly in the frame.
Motor vehicle Automotive tire Automotive exterior Bumper Gas
Generator and cam covers off helped.
Hand tool Tool Metalworking hand tool Wrench Auto part
Time to organise bolts/plating. One of those triple clamp bolts looks wrong!
The plate and possibly the spacers should be black, so I'll paint those.
Having put the front mounts on the wrong way around, swapping them around soon has the engine sitting in the frame in the right place. There is an oil cooler mount to go onto that left mount as well, but with the rear mount bolt temporarily in place, I can be sure the engine is sitting about right!
Motor vehicle Automotive design Automotive tire Vehicle Hood
Motor vehicle Wheel Engineering Auto part Automotive design
So here is where we are as of this morning! Now for work!
oh, and I had a nice delivery yesterday as well..
Circuit component Electrical wiring Cable Gas Coil spring
As ever, more as it happens, although there might be a break in proceedings, as I'm riding to wales for the weekend on Friday, sadly not on the AT.
Discussion Starter · #87 ·
After a short pause, things are moving again.
Once the engine mounts were bolted into place, I had to get the fram upright. Here's where an engine crane comes in handy again
Tire Automotive tire Wheel Motor vehicle Automotive design
It's great to have plated and painted parts to go back together..the silver plates were ceracoated.
Automotive tire Motor vehicle Automotive design Vehicle Rim
Automotive tire Product Hood Automotive lighting Motor vehicle
time to assemble more of the swing arm
Hood Motor vehicle Bumper Automotive exterior Vehicle
Swing arm ceracoated, other parts blasted and re plated
Bumper Automotive exterior Gas Auto part Motor vehicle
Screws were new though.
Ready to go in!
Hood Bumper Automotive design Automotive exterior Wood
Motor vehicle Hood Automotive design Automotive exterior Bumper
the waiting recipient!
Automotive tire Motor vehicle Vehicle Bumper Automotive exterior
the powdercoating makes these fitting a very tight fit. Chipped the finish in two places here, so touched in, but it might be worth masking these areas if anyone is contemplating having their frame powdercoated.
Gas Engineering Machine Auto part Ceiling
but getting there!
Motor vehicle Automotive design Engineering Rim Automotive exterior
I'll do more over the weekend....thinking head bearing races and forks!
81 - 87 of 87 Posts
