Hi All,
I picked up my new Transalp 600 from Phil W recently and took it out for a quick ride last night and stopped for a couple of pictures as it was a nice spot:
Discussion Starter #2
One curious thing though, should my rear rack look like this ... looks like its missing something, anyone know what should be there, or indeed where I can source a replacement cheapish? :
cheers
There is a top plate that fixes to it using the 6 threaded holes.. two Honda types, one thin so you can strap stuff too it, one thicker that can take a U lock.. but they are often replaced with Givi or kappa top plates for top boxes.. if you ger a toopbox with the matching plate then you can mount that :thumbup:
cheers
Anyone know whether one off a Dommie will fit? If so, I have one sitting in my garage that takes a U-lock.
What's the measurements between the holes?
they are all the same one of an RD07 i picked up fett my RD03+ and the 600 TA
should fit, worth a try
Thnx guys for the info :
'There is a top plate that fixes to it using the 6 threaded holes.. two Honda types, one thin so you can strap stuff too it, one thicker that can take a U lock...
should fit, worth a try '
cheers raymo - as I wont always be using a top box, sometimes just strapping a soft bag on the back it looks like I need to source a 'top plate'
'Anyone know whether one off a Dommie will fit? If so, I have one sitting in my garage that takes a U-lock.
Alan - I'll measure mine tonight and let you know if thats ok but its sounds promising
