Looking for new tyres for the transalp. At the moment it has 90/90-21 M/C 54s Trailwing 47 front and 120/90-17 64s Avon on back, both I think are mainly off road.
All my riding is road in UK.
My question is this, I know i'm governed by the rim size, but what about the 90 and the 120 can these be bigger and so would they be any better or should I stick with these sizes.
Regards
Pete
Front tire is 90mm width w/ 90 as pect ratio. The aspect ratio means the tire's height is 90% of the width. In your case, it ends up being 81mm. You need to keep the tire height id you go to a wider tire. Therefore, you could theorically fit a 100 width and 80 aspect ratio. That is if the rim can accept a slightly wider tire. The same applies at the rear.
120mm width and 90 aspect ratio leads to a 108mm tall tire. If you wanted wider and a 80 aspect ratio, then width could theorically be 135mm. So, you best choice is either 130mm or 140mm wide with 80 aspect ratio if your rim can take it.
Lee
Lee
bridgestone bt 45's are what you want if you want the best road tyre they not the cheapest but they are most lightly the best ? its best to stick with standard sizes but with a bt45 you might get away a 140 on the back . if you want a fatter tyre but it can cause problems with pinching tubes .
I'm about to replace the rear on my TA 2002 650. I looked up best road tyres, I've always used BT45 on my cb500r, never had a problem. I do 400 miles a week on roads, sometimes slushy muddy little lanes too. I've heard Avon gripsters are a good option, but I'm getting confused about the sizes. I can't find Avons in 120-90/17, I have seen them at 130-90/17. I'm a short and stumpy sort, so if these tyres add any height, I'm in trouble! Any advice?
hello pete, im new to the transalp 650, bout a month now ! personally ide stick with what the book states for sizes, dont forget with insurers they can get very funny with the wrong size eh in the event of a claim eh ! continental trail attacks or michelin anarkees are great ! friends have them already !
