Hi, just aquired a 1982 XL500R, and found this site - so saying Howdy. Already know M6NTL from another site ;)
Its a UK bike, 17500 miles, not been on the road since 1996. All original, except the Micron exhaust system. Overall in used condition, but untouched, with all original stickers too :thumbup:
The motor is sweet, no undue rattles or smoke, but runs a bit lumpy - so cleaned the carb out - full of red ****e.
As I usually get the hacksaw out to my bikes, I'd like to keep this one fairly standard.
Much prettier than mine!!!
You need to upgrade the front brake tho (IHMO), stopping requires written notice with drums!!!
Yeah, was on eBay - I had a mad 5 mins - placed a low, but reasonable bid - then within an hour, won the beasty :eek:
You should have seen the missus laff ;)
Red Blooded Biker
I used to have a drum on the front of my XL250SA. When it came time to replace the brake shoes I tried the cheaper EBC ones & they were absolutely rubbish...even after 200 miles of running them in there was such & time delay & even then the braking was minimal. So I bit the bullet & ordered up the OEM ones from Honda & they were a complete revelation...instant differance right from the off. So it may well be worth checking to see what make the shoes are on your nice clean XL500R...nice bike...
:thumbup: Cheers for the "head-up", I'll be taking your advice soon, and having a look...... they do pump a bit too, so the drum maybe warped :(
The bike has been running a bit better, now I've fitted a new coil, plug & ignition switch..... but needed the choke "on a bit" to smooth it out - soooooo :confused:
I took the carb off (again) and cleaned it out - and noticed it had the equivalent of a #120 main jet - too weak :(
So, best I had was a #137, so whacked it in and its transformed the bike :thumbup: (its got the Micron pipe)
I must say its so much better than me old (2004) Yam TTR600 - as it seems a lot lighter and quite perky for an older bike. The front end easily will lift with just a slight tug on the bars :iconbiggrin:
Still a real pig to start though :mad:
