Easy as pie to fix a noisy facit fuel pump, mine has been getting worse and worse over last couple months. New fuel filter: Noise gone, totaly. Quite a handy thing really as I never quite knew when to change the fuel filter before. Now I know that when it starts ticking the fuel filter needs changing!
I hope this helps some other too!
George
Thanks George :thumb:
It's the running out of fuel and overheating that burnt my original pump and then my facet pump out :eek: Clogged filters don't help :rolleyes:You live & learn.
Got a Pierburg one on now but always try to keep her well fuelled. :D
My Facet started knocking yesterday. I tried to blow old filter but it didn`t really help. I did order new one but I`ll get it thursday.
Could fault be in filter, if i try to bleed fuel out it runs freely. :confused:
Noise is gone.
I did clean filter from tap, renewed filter and once tank was dismounted emptied carbs. There was some water lying in.
What kind of mileages has Facet pumps been running?
EDIT:
Noise came back and installed original Mitsubishi.
Facet lasted about 15tkm is that normal?
