1 - 20 of 24 Posts
Anyone taken the oil strainer out of the bottom of their frame?
Tried removing it yesterday, so i could check it, and get frame ready for powder coat, but could not get it to undo.
Tried interlocking two spanners to get a higher torque, but still no joy.
Any tips on removal???
Hi Scotty, Yeah, the strainer can be a right pig to undo. The torque setting on it is a fairly hefty 40Nm. Last time undid mine, I slid a 3ft length of scaffolding pole over the spanner for some serious leverage.
Be careful they can round off easily i know mine was abused from a previous owner and i made it worse :( if you take the oil pipe off you can get a socket on there and use an impact gun or power bar try and use a hexagonal socket rather then the multi point ones good luck :thumb:
Thanks both for the advice.
I can see that someone has slipped with a spanner on previous attempts, that's why i was being a bit cautious with it.
Is there a copper washer or o-ring that i will need to change when refitting the strainer to the frame? (if i get it out :toothy8:)
Stone Crazy
THe SLR/Vigor handbook says just to blow the filter out with an airline and nothing else
Thanks All for the info.
Does anyone know the thread size of the strainer?? the side that screws into frame.
Need to find something to plug the frame once i got the strainer out.
Decided to have another go at removing oil strainer, after reading the post about an impact gun, thought it was about time I took mine out of its packaging.
Why didn’t I do this sooner, plugged the air in, pressed the trigger and out the strainer came.
Was surprised how clean it was, but glad I did it before having frame painted, at least I can give the frame a proper flush out now.
Need to get a new o-ring now, as someone had repaired it with mastic/sealant
There's a strainer in the engine as well it don't need checking very often i checked it when i rebuilt the top end in 2016 and the time i checked it before that was five years earlier clean both times
Discussion Starter #14
Hi Fred
I got the RH crank case cover off and was wondering if I got to take anything else off to get at the internal oil strainer.
I can’t seem to see it??
Its right at the very bottom of the crankcase under the clutch basket you have to undo one bolt and pull it out
I tend to check that a few hundred miles after a rebuild, I had a bad experience many years ago after rebuilding my xl125 they had a gauze filter that had blocked up with all the fluff off the rags i was using to wipe things down seized my freshly rebuilt engine i was gutted. Got the top end off my XR400 at the moment and i will be checking that after its done just in case. :grin:
1 - 20 of 24 Posts
