1 - 2 of 2 Posts
Hi Folks,
i have a little Problem with my Varadero.
From the Bypass Hose (Overflow @Waterpump), comes a little bit Oil. See example Image.
The mechanical Seal and Oil Seal was Changed, but the same Problem is still there.
Can someone Help me ?
Best Regards
Markus
165264
The new seal has to be carefully pressed in to spec - plus the gasket has to be carefully put on so only coolant can leak if the seal fails to stop water in the oil. - sounds like something hasn't been done properly in the repair.
1 - 2 of 2 Posts
