1 - 2 of 2 Posts
the twin has a slight oil leak on the clutch casing were the cable arm goes into the top....what i need to know......is there a seal or some type of rubber gromit i can replace to stop the oil coming out the top of the casing.....thanks kevsky..
Yes there is a little O ring and a small bearing (thats if it the same as my old RD03 I had) I change both as mine had a leak from there, easy to do but you need to take the cover off to get to it.
1 - 2 of 2 Posts
