I’m on changing the output shaft on my 700 XL and having started it up after the rebuild I am getting a very light noise from the clutch side, my question is there anything that is peculiar to the clutch to make it noisy. When I pull in the clutch lever the noise disappears.
, there is also a little play on the clutch basket and the oil pump drive chain is a little slack.
Also does does anyone know the max oil pressure for the 700, when the engine is hot (fan cutting in 103 deg C) on tick over is around 30 PSI but when at 5000 RPM it is almost 100 PSI which I think is too high.
Discussion Starter · #2 ·
Oil pump Drive chain
