chrisb
time to replace sprockets and chain. Bought Honda parts off Mr. Silvers. All going well this evening but could'nt quite squeez on the joint link plate onto the pins using a molegrips ..so..out with a small G Clamp and an M6 nut...ooopppss..too much ..distorted one of the O Rings. I can see it distorted. $iht..now, hands up , will I leave well enough alone and continue on regardless or will I ( can I ) buy a new Joining Link and press out the old one and have another , lighter handed attempt ? Dont suppose theres too much harm in riding the bike in the meantime. Is this link available as a seperate item from Honda ?
Thanking all replies.
Chrisb
won't any matching rivet link do the job? You should be able to buy from anywhere that sells DID or RK chains- or that's where i'd be looking anyway
That's where I got my spare link from. Quick turnaround.
If you haven't peened over the end yet (assuming it's a rivet link), try gently levering the side plate with a wide screwdriver to move the side plate back out again. Don't damage the o-ring and don't use excessive force on it. Gentle persuasion is the order of the day.
