Oops,
So after taking a couple of bits to the powder coater he tells me he's going to be away working for 5 weeks, out come the spanners and look what happened to my bike! I have to say I was pretty chuffed no seized or rounded bolts and the shock linkages nice and greased.
I'm going to change the steering head bearings as they are just starting to show some spots on the top bearing where they have been resting, is there a preference to using ball race or taper race bearings here. It still has balls fitted.
The throttle return cable has snapped, I've read a few posts about these, is it worth replacing? Do we have any preference to aftermarket or OEM cables, I'll change the clutch cable as well as it's been sitting on the exhaust and melted the plastic.
I was thinking about replacing many of the M6 & M8 bolts on the frame / engine mounts with stainless ones rather than clean them up and painting them, is there any issue with using stainless into the frames mild steel nuts?
Now it's offshore for 2 weeks jail time to think about what I've done to the old lady....
