1 - 2 of 2 Posts
I am using this site to try and order some bolts that I require to put the original backend on the bike
https://www.fowlersparts.co.uk/parts/5157420/xrv750v-1997-e/seat-2
question I have is this, to order the bolts for the carrier(I have the collars) it shows bolt number 27 for the middle ones. There are two holes so two bolts. On the list below for number 27, it says 'quantity used:1' . Does that mean there are two bolts in the pack for that or is there a mistake on the site and I would need to order 2 of them. I need a few bolts and its adding up, so just want to make sure I order the right amount.
cheers
I’m sure the site is wrong with quite a few quantities, the bolts are sold singular, so if you want 2 order 2.
Bolt 27 is m8 x 50mm, (8x50) flange head. You can buy these size bolts on eBay much much cheaper, the only difference will be the bolts from Fowler’s will use a 12mm driver compared to a 13mm.
You can also buy in stainless or a zinc finish to reduce rusting over conventional black steel bolts
1 - 2 of 2 Posts
