1 - 1 of 1 Posts
I have a 1994 RD07 which I'm taking to bits to replace the countershaft + bearing(very worn splines). I would quite like to repaint it in later model blue (PB 273M) and red (R127?) RD07A colours. Can anyone recommend someone who does good work in the Oxfordshire/Buckinghamshire etc area....preferably not too expensive... Also looking to get the clutch and generator cases cleaned up (blasted?) and polished - any recommendations appreciated as well. Recommendations for blasting and repainting the frame also appreciated.
Measuring the clutch friction plates seems to show that they are between 3.78 and 3.80mm thick. Should I replace them as a set while the bike is apart along with the springs which are definitely shorter than the Haynes specified minimum?
1 - 1 of 1 Posts
