Hi all,
Is there a easyer way to set the mixture on a 125cc?
Going by haynes screw the pilot screw it in until it seats then back out 2 3/4 turns then adjust to find highest consistent idle speed then screw back in to drop idle speed 50 rpm then back out 3/4.
And you need a rev counter with variations of 50 rpm.
Thanks.
Discussion Starter · #2 ·
I have been read haynes manual and can someone confirm the following -
The initial setting for v4-6 is 2 3/4 turn out but models v1-3 are 1 turn out and shadows are 1 3/4 and 1 1/2.
I don't understand why v4 -6 models are so much more!
Just want to make sure it's not a miss print.
Thanks.
I need some help with my varadero 125 it's an injector model not carb.....bike starts with one swing on rare occasions it will give a hard swing but the problem I have is that just when I'm about to give gas it has a delay like a flat spot i believe it has to do with my gas and air mixture can anyone give me the correct adjustments for the screws??
