Hi AT friends, would apreciate your help again
I will get a top end engine job done in Malaysia soon. Hopefully just change of pistons rings, but who knows when opening..
My mechanic (Sunny cycle in Kuala Lumpur) says i might also need a slightly bigger piston. He says you can get pistons only a little oversized , where you (might) not need a new bore. He says standard Honda pistons need a new bore (to big).
Are these oversized pistons from cmsnl.com standard oversize and need a new bore?
PISTON (OS 0.25) product number: 13102MV1305
PISTON (OS 0.50) product number: 13103MV1305
If those above are not right, what are minimum oversize and where can i find and order please?
I would need them in Kuala lumpur, so any suggestions to where to order from that ships there?
I have this gasket set and new standard rings/oil seals - anything else I should have with me?
Motor Gasket Set Athena Complete for Honda XRV 750 Africa Twin XRV750 1990-2003
Apparently engine parts for AT's are almost impossible to find in Malaysia, so mechanic asked me to have a connection where i can order pistons fast if needed.
Thanks and happy riding guys
