Hi all
My RD07A developed a fault in May 2019 which I am now going to try and fix.
It ran for about 40 minutes 25 miles and died. Sudden loss of power and it coasted to a halt. Restarting showed there was no engine turnover. Slowly over about 4 hours (the time it took for the recovery truck to arrive) it came back to life and cranked over so I was able to ride it up onto the recovery truck.
A race mechanic I know has suggested thermal cycling where the engine overheats and the pistons stick in the bores. Hence why it got better as the engine cooled and was able to crank over, so not a charging/battery problem. It also starts fine on the drive with the bike on a CTEC charger but I don't want to ride it anywhere to try and replicate the problem or it will stop and I will be stuck again.
My question is how can I check the cooling system to diagnose what I need to fix?
Will be done at home on the drive prior to ordering the necessary parts.
Thanks for your knowledgeable help
John
John
