1 - 1 of 1 Posts
I was reading a ridiculously long thread on a Harley forum all about front suspension (as one does) and much was said about setting sag, after installing bespoke springs...as far as I'm aware, my 954/5' 600 has the long fork springs installed, ie there are no spacers between the spring tops and the fork caps, unless you count the plain washer. Either that, or someone has removed the spacers...
Does anyone happen to know if the older, shorter springs sit flush with the fork tops before the spacers are fitted (with the tubes fully extended), or do the springs sit lower in the tubes with a distinct gap for the spacers? Without taking the springs out to measure the free length I'm non the wiser....
I'm thinking to buy some adjustable preload caps and was wondering wether I'm starting from the right place....
Thanks in advance....
1 - 1 of 1 Posts
