Well, I've just fitted new rear pads and typical of me, I take every opportunity to lube and clean all pivots etc.
So, any of you out there who follows the Haynes manual for changing pads, wait a minute and do a bit more than they suggest.
They say about pivoting up the caliper so that you can change the pads. But, if you don't remove the front caliper bolt, from the rear caliper
it will be a reeeeeeeeeeeeeeeeeeeal pain at a later date.
(Oh, just a point, you don't need to remove this to change the pads, I just suggest that you do.)
I got the bike with 6,000 miles on it and am just approaching 20,000; first time changing rear pads on the Transalp.
As, I wanted to clean around the piston, this meant undoing the caliper totally. I would suggest you do the same each time you change your pads; no I demand it in case I end up with your bike
That front bolt was a b*gger to get out. Whilst obviously trying to use just an Allen and then with extension bar, I resorted to WD40, 'taps' with a drift and a Impact Hammer.
This obviously helped, because an Allen key with an extension bar on the end, eventually moved it.
So, when you next change the pads, don't just change them, take the opportunity to clean the piston, re-grease the caliper pivots and copper grease the pivot threads.
