open to offers
Hi guys, I want to fit some projector beam lights to my @, but I'm not sure where to take the switched live from, any suggestions? I will be using a relay and fuse to a separate switch, I was thinking side light live, any thoughts either yes or no, or NOOO!:mad:
geriatric
thats where I take the live for the relay from. main feed from battery fused, relay switched on when sidelight goes on.
geriatric
I've got 55w hella de's, I run a feed from the battery to the relay, then on to the two hella de's and earth the two lamps direct back to the negative on the battery, the feed from the sidelight goes through a switch to the relay to activate it so if the ignition is on and therefore the sidelight I can switch the spots on and off while riding along with a flick of the left hand. Never had a problem and we wired grumpyoldgit's exactly the same.
open to offers
Lovely, just what I wanted to hear, back to the garage! Thanks for the info:thumbup:
