hi lads
finally fitted the NgK plug caps, im now an expert on removing the right hand panel , after fitting and removing it 3 times
Pity the left hand side diidnt have as much care the previous owner must have broken the lug that holds the panel in , blue tack was doing the job, ill be on the look out for a replacement panel now , and by the way the transalp is running alot smoother
Neil
Neil
