1 - 15 of 15 Posts
My 700 has always run a bit hot. I am thinking about swapping those 2 tiny radiators for a single large one. My question is would it be a simple swap or is there anything there to stop me doing it, some technical reason? I guess radiators are pretty simple but would like to hear from someone who has done it.
Administrator
Does it really run hot, or is it just that the gauge reads hot? If it's really running hot, is anything obstructing airflow to the rads? Does the fan work as it should?
(Given that the bike's been sold in"world" markets, its cooling system should be more than adequate for Britain's cool climate).
I think Mr Honda uses the twin radiators because there's a frame member in the middle that would obstruct airflow to a full-width single rad .... the centre section wouldn't really be effective as it's out of airflow
Xi dwejjaq member
You could try servicing the cooling system. Flushing it. Putting in fresh coolant and ensuring that the cooling system is properly bled.
How hot are we talking about? Normal running in mild weather mine normally sits on about 76 degrees. Once I hit either town or slow traffic it soon starts to rise, 80-90 degrees is normal. When riding in very hot conditions or/and lots of stop/start traffic it's not unusual to see 104 on the gauge.
Nick.
Thanks for the replies folks. I rode around town yesterday and hit a bit of traffic and the fan was kicking in already. It's March and temperatures are low. I know how 700 are, I had mine for about 2 years now but it drives me round the bend still.....that is why i thought of upgrading the radiator. The fan kicks in when the temp reaches 103C, I guess I just have to live with it.....
Presume from your location this is occurring in and around London - if so it's not to be unexpected. I bought my TA650 in London and it got quite hot with fan kicking in on the ride home across the congested city an overcast May Saturday afternoon. Never got that hot since in the 3 years I've owned the bike.
As already suggested service the cooling system so its doing its best.
Discussion Starter · #8 ·
Cheers Vicky, I have thoroughly flushed the system and put in new coolant, checked all the hoses and rad cap, as well as radiators for leaks. Basically I have done all it can be done that is why I am asking .....although I can be obsessive about things
Mine runs at 78-80 nothing unusual ,that is until you get into some traffic , then the fan kicks in every few minutes ,as soon as you hit a break in traffic runs fine. If you have flushed (including rad) and replaced coolant and cleaned between rad fins (carefully) should be all good.
Nothing wrong with being obsessive , it's the difference between thinking and knowing something is done .:thumbright::thumbleft:
  • Like
Reactions: queasy rider
The fan does come on quite a bit on the 700, if so and the temp comes down, I wouldn't worry about it.
I have a 700 Transalp XL700-VA9
I agree that the fan does kick in very often, even in cool weather.
Currently I have a small leak, about 150 ml in a tipical run of 60-70 miles over 2-3 hours. I have been just carrying a bottle of mixed coolant & topping up prior to the return journey.
My question is, Would the engine suffer if the radiator were to run dry & rely on AIR cooling. ?
I have been topping up via the radiator cap which is impossible unless you remove the plastic "bridge" piece that connects the 2 tank panels.or the rh tank panel. I had been running with the tank panels removed as it makes a lot of jobs much easier. The first thing that the manual states before starting many small tasks is "Remove tank panel/s"
How sucessful would it be to just top up the header tank, which runs low or empty & rely on the low radiator sucking coolant from the header tank. Not ideal I agree but a lot easier than removing plastic panels at the roadside !!
I am contemplating sourceing a replacement, second hand radiator.
Any assistance would be greatly appreciated.
If you run it dry it will wreck the engine. Dont know if these fit, but they’re much cheaper !
or contact the seller n see if they can help
1 - 15 of 15 Posts
