Can diaphrams go bad without being holed or ripped ???.
The reason i ask is i still cannot get to the cause of my misfire on my RD03. I've replaced so many things i've lost count.
I borrowed Roadkills carbs and it went like a rocket, His carb number ends CC7 and mine end CD7, Everything else is the same, jets , mains, needles,float valves etc etc.
One thing i did when i had Roadkills carbs was to start the engine with the air box off and you could clearly see the slides dancing up and down on tickover, when i reassembled mine this morning i did the same and my diaphrams dont move at all till about 3000 revs and seem slugish in rising when opening the throttle unless you quickly open it full.
Ive already taken the diaphrams out and inspected them and theres no rips/holes in them, they are a bit baggy but i would say that Roadkills looked worse than mine.
If the slide isnt rising as it should then this would produce a misfire/ loss of power as it would be starved of fuel at a certain throttle position......................................................................... but the diaphrams look ok.
let me know your thoughts before i blow another £100 on new diaphrams that it might not need
