Hi all!
I would like to do the full overhaul and maintenance of the fork of my RD03.
As far I understood, what is mandatory to buy is:
-2xdust seal
-2xoil seal
-oil
what I am not sure of, is if I have to buy as well:
-bush guide
-bush slider
Thanks in advance for the help!!
Might want to pop the dust seal off and check how badly rusted the spring clips holding the seals in are
There will be a measurement in the workshop manual for the bushes in the forks. That and the measurements of yours will be the deciding factors.
Hi all!
-2xdust seal
-2xoil seal
-oil
-bush guide
-bush slider
Regarding the bushes, I normally inspect them, if there are any signs of damage or scoring or the grey coloured low friction material is starting to wear thin, replace them - or be on the safe side & just replace them anyway.
I always use genuine parts for bushes and seals.
For bushes is probably tho genuine, though I've never had a problem with after market oil seals, over several sets of forks .
