Hi all, I removed the front sprocket as i've heard horror stories of stripped splines on the output shaft and even some being welded on !!.
My splines look good but when i look at my sprocket all the teeth dont look that worn but looked slightly kinked over (see pic), also on one side there is some strange wear marks following the link pattern, Is this normal or is it time to replace that as well.
Could it be that the sprocket was on the wrong way round, it was fitted with the thick flange to the front with jtf296-16 showing, the wear is on the back face of the sprocket which would seem to indicate it was on the wrong way round and if the flange was nearest to the engine it would bring it away from the engine. Its as if the chain was not running in a straight line and rubbing on the rear face because the sprocket was too close to the engine and out of line.
The chain itself has a few seized links ( chain not straightening properly) but i was going to try and free this off with penetrating fluid a vice and some elbow grease. Tell me your thoughts please.
