Hi guys
I'm Marco from Belgium. I have an RD04 from 1990. It's a great bike, but has had some bad owners that didn't maintain it. :(
I have replaced the rubber inlet seals, valve cover seals, fuel hoses, blablabla... =)
Now i am left with one part: a screw, a tiny washer and something on the screw. Who know where this part goes, because I can't remember it. I can't see it on the exploded charts.
Some pics:
Thx !!!
Gr, Marco
That looks like a hose clamp screw not 100% though
Hi!
Thx for the quick reply , that looks EXACTLY like the hose clamp. And now I remember where it should be installed!
My crankshaft end cap is toast
Previous owners have ruined the hex. And I demolished it. Any easy way to remove it so I can replace it with an end cap with extruding Hex ??
Like these?
CCT replacement/ alternator bungs - Page 5 - VTR1000.ORG
Drift the cap off carefully with an old screwdriver (or punch/chisel) in the undo direction at a very shallow angle.
just be careful how you hit it when trying to use a drift.
If you tap four small centre punch marks in, and then place the punch at a 45 degree angle to the casing, drifting the cap in the "undoing" direction it should come loose after a few taps.
Hit it about 5mm in from the outside edge, because the part that carries the thread and extends into the opening is under this; you're less likely to snap off unsupported areas.
Don't hit it too hard because you can punch a hole in the generator casing!
