1 - 11 of 11 Posts
Hi
I have a XRV RD04 1991.
Reading all service manuals and visiting all websites in the world, don't clarify which needle jet holder goes where. One have 6 holes - one have 10 holes.
My logic tells me, that the one with 10 holes is in carburettor 1, since its jetted a little larger than carburettor 2, but i honesty don't have a real clue.
Does anyone in here know?
Best
Dan Lumbye
PS.
I'm actually a little bit surprised, the servicemanual don't clarify the fact, that the two carburettors are different.
Have you checked the parts list ? The emulsion tubes have marks to identify them.
Hi ML
I have checked all my usual sources (cmsnl, wemoto etc.) I also have the original partsfiche. All sources describe two different partnumbers: 16165-MV1-630 and 16165-MF5-671. But none of them tells me, how the looks. I Also have both Haynes manual and Hondas servicemanual.
Best
Dan
Hi
Thanks, but that's jut one of many guesses. I would really prefer the fact from someone who actually know it.
Best
Dan
Does this help with part identification? Both are 16165-MF5-671 - 10 hole jet
Looks like Transalp 600 have similar jetting - forums say that the needles are marked, with an A of the front cylinder, and with a B of the rear
Suggestions on other threads is again that 10 hole jet is front cylinder
According to the part fiche in pdf format that I have:
Front emulsion tube is 16165-MF5-671
Googling 16165-MF5-671 gives me the following image showing 10 holes
Rear emulsion tube is 16165-MV1-630
Then going there : http://www.xrv.org.uk/forums/africa...n-rd04-xrv750-engine-restriction-details.html
I get that
Front/Right Holder, Needle Jet, Part No: 16165-MF5-671
Left/Rear Holder, Needle Jet, Part No: 16165-MV1-630
Discussion Starter · #10 · (Edited)
Hi
Thanks a lot. I thought i have looked everywhere :)
It seems to be totally certain now.
Still wondering, why it is so secret in the manual though. The needles are also different and not mentioned in the manual either.
Best
Dan
dragging up an old thread here, my original RD04 carbs have two 10 hole needle jet holders, as do the replacement austrian restricted carbs. the original carbs had damaged choke receptacles so im swapping everything over, will i be fine to run 16165-MF5-671 in both front and rear carbs? i will run the Original needles in correct orientation and 118/122 main jets. Cheers
1 - 11 of 11 Posts
