So, heh, ever since raising the bars up to their maxium height (though rotation) the clutch lever contacts with the handguard strut so I'd like to change the lever for a short one.
Any recomendations?
Even with aftermarket bars, you can easily fit weights. Moving the hand guards away leaves more room for your hands. I haven't yet installed the clutch side because the thickness at the bolting point shall be 8.05 to 8.1mm and the levers are 8.2mm thick. I have to force it in, and it will run. I will gently file the lever around the bolt hole.
Cheap handlebar weights.
Useful Anti Vibration NEW 2Pcs Motorcycle Handlebar Bar Ends Plugs Weight Black | eBay
Short levers.
