today my 04 melted the junction and fuse on the starter relay according to green flag man.where do I get one please and is this just the problem or is there anything I should look for please?
Yes, they do that. It corrodes and then develops resistance in the connector. This then gets hot causing more corrosion, more heat, more corrosion ...
... and eventually it burns out.
You'll probably need a new connector as well as the new solenoid. You can get a pattern solenoid here: Honda XRV 750 L/M Africa Twin RD04 90-91 Parts at Wemoto - The UK's No.1 On-Line Motorcycle Parts Retailer
There are sources for the connectors too but you won't get them from Honda. Someone will hopefully chime in with a source for them.
