Hi all,new around here as I recently bought my Africa Twin,it leaked out of the bowls when I got it I replaced the O rings and it was fine now it is leaking from either the bolt you empty the bowls from or the weird hose that also connects to the overflow hoses from the carb,I cleaned both of the carb emptying screws and their seats really good and I thoroughly inspected the rest of the carb all seals and O rings look OK any advice before I mount the carbs back up?Thanks !!(Photo of where the weird overflow hose connects to ?)
Leaky float valves coupled with incorrect spec pump. What happens if you leave the fuel tap 'off' when parked?
It indeed has a vw golf pump and it only leaks when warmed up and running when it's off it doesn't, though it wasn't leaking anything for the 2 months I've had it so that's why I did not blame the pump,the float valves are mint and not leaking
