1 - 12 of 12 Posts
Have you had the bike long..what oil is in it ? Is it due an oil change ? If it got a really thin grade oil in it will use more. Needs a proper bike oil of at least 10/40..could try a 15/50 if your in hot climate.
Discussion Starter · #11 ·
Ok, I decided to do engine work. Will get first of all both heads to check, bottom will go after ill be sorted with heads.
After bottom end will be checked i will decide what to do. To get oem pistons or to go oversize project
Discussion Starter · #12 ·
Ok, i have bike for 2-3 years, year ago it was underwater. But i'm not quite sure oil consumption got worse from that day’s. I use 10w40, owner before me, used to use 20w50
1 - 12 of 12 Posts
